which automatic wire stripper is the best? | on ElectriciansForums
Discuss which automatic wire stripper is the best? in the UK Electrical Forum area at ElectriciansForums.net
T
Tim Brennan
Hi All,
I had to replace my old automatic wire stripper as I broke it. The replacement unbranded device is the same but it is rubbish. I'm looking at the C.K 495001 Automatic Wire Stripper as a replacement of the replacement.
C.K Automatic Wire Stripper - http://www.screwfix.com/p/c-k-automatic-wire-stripper/97204
Anyone had any experience of the CK tools version or can you recommend another brand?
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Ck ones aren't great had 2 sets fail on me, haven't tried any other brands. They are a handy little tool when you've got a lot of stripping to do or sometimes getting into certain cables is easier with the stripper than snips.
You know what I reckon? with all these tools for stripping this and that, some one will start courses on cable stripping imagine, "what qualifications have you got the Son" well I'm Part P and cable stripping qualified.
I know what your saying Pete , but for testing at first fix it speeds it up five fold .But yes of course you should be able to strip manual
Have a set and they are well worth the money.
once set they will reliably strip very fine alarm cables right up to 6mm. They will strip the outer off 1.5mm flex and the outer off upro 2.5mm T&E all with no further adjustment.
They have taken a good hour of my time for wiring up a heating control panel and associated valves and switch gear, but I am notoriously slow; I prefer thorough.
Been using them heavily for a couple of months now and they're showing no signs of wear but at ÂŁ20 a set they are paying for themselves on one job.
good addition to anyone's toolbox.
To be honest and whilst not wishing to knock wire strippers, never owned, used or wanted a pair, if they suit you all well and good, waste of money imo
Same here, I personally don't know any sparks who use or even own a set.
Don't know about the ones you linked, but my mate is on at least his fourth set of CK shears approx ÂŁ20+Vat to my 1 cheap set which where only ÂŁ8.50 plus Vat in the wholesalers.
His struggle to keep their edge long term and wouldn't get abused. I don't think CK are as good a brand as they were 20 years ago.
I didn't have a set for years, got some about a year ago and now I wouldn't be without them.
Mine are a set of ÂŁ9 specials from wholesaler, no brand on them. I looked at them side by side with a set of ck ones an auto electrician friend of mine has and they look identical. I'd bet they were from the same factory.
Strips up to 4mm t&e, and can strip all 3 cores of a 3c&e in one go. Saved a load of time. I'd they break I won't cry at ÂŁ9 Inc vat either.
These strippers are brilliant... strip T&E, flex, three core & E, just about anything very easily. I have 3 pairs because I could never be without one... There are other types that strip face on instead of sideways, but I've not used them.
Reply to which automatic wire stripper is the best? in the UK Electrical Forum area at ElectriciansForums.net
I'd go for strippers every day, wire and cable are just plain boring! Definitely get yourself a stripper! (Failing that Id use ck crops)
