Which brand of switch/socket should I change to? | on ElectriciansForums
Discuss Which brand of switch/socket should I change to? in the Electrical Tools and Products area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I have used Crabtree for years. It's still ok, but I just don't like their sockets, as they stick out quite a bit compared to say MK or even the Lap ones.
Which brand is good to use? I do like the look of MK, but it's a bit expensive. I tend to buy in bulk and keep it in stock.
Hager sollysta is pretty good, the amount of packaging and these little white covers are a bit of a pain but look good when fitted,
Prices are ok online with most wholesalers stocking them also if you get caught short of stock
I've been using Click Mode for years too, decent quality accessories. But recently I've been trying Niglon, they're all but identical to the Click but even better value.
Been using Click Mode for a good while now with no problems,
The interchangeable plate switches mean you configure them to your exact requirement
sticking with these till something better comes up. obviously i use the plugs with the fuse L pin to comply with curre nt regs. ??
[ElectriciansForums.net] Which brand of switch/socket should I change to?
Click mode for me as well. Generally because of the versatility of being able to change modules in the switches.
Who are you? ?
Cheers all, reckon I'll give click a go. I checked out a few older threads and it was pretty much identical suggestions. 80% click, 15% Hagar and 5% other.
Reply to Which brand of switch/socket should I change to? in the Electrical Tools and Products area at ElectriciansForums.net
Which truly is the Number 1 Best Tile Adhesive Brand? Since 2007 Tilers Forums started an annual best tile adhesive Poll and sent it out to the...
When I first started, I stripped out a house for a rewire and got my hands on a switch with an inlay and transparent cover. Filled it in with...
