Which CCTV do you recommend. | on ElectriciansForums
Discuss Which CCTV do you recommend. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Manchester
Hi everyone,
I’m a qualified electrician been retired now for 2 years.
I’m looking for a bit of advise
My son is having problems with his neighbour and wants to fit 2 x Cctv cameras with audio.
Would like a system that is easy to use
What can you recommend?
Hikvision have been recommended several times on here.
Or if you just want a cheap and cheerful option then there are loads to choose from that do the job. They aren't always as easy to set up though.
Another vote for Hikvision from me. Easy installation, easy set up, good quality. Mine worked out of the box, and all i needed to add was an extension power lead due to the actual location of the camera. The extension is about 10m and cost buttons from the usual sellers.
I’ve got Swann security at mine. Easy enough to set up and run the cables, can get wireless cameras if you don’t want the faff with that and don’t mind spending a bit more.
Esp rekor would be suitable for domestic cctv. Hic overkill for domestic imo. Great for commercial where better pic is req and customer has ÂŁ to spend
Reply to Which CCTV do you recommend. in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Also good for cutting strands of cable armour, although I try to restrict their use to copper.
nicebutdim
N
I use Xero for invoicing and sending estimates I use a different program (Quicken - not Quickbooks) as I have had it from 2004 and it still...
