HappyHippyDad
Supporter
I am going to need to install a small amount of galvanised steel conduit, leading down to perhaps 4 sockets and a light switch. This is in a domestic premise. The customer wants the industrial type look and they want it looking very nice, they are happy to pay the price for this.
I have found 2 different types of wall holders and wondered if these are what are usually used, or if there are more options? Option 1 looks nicer but i don't thin it would work.
1. Brass Munsen Rings 22mm 5 Pack - Screwfix - https://www.screwfix.com/p/brass-munsen-rings-22mm-5-pack/8699V?kpid=8699V&ds_rl=1249404&gclid=Cj0KCQjwz6ShBhCMARIsAH9A0qUCFGWJoYE3Jy86ysR0qEStLGnHKSWH0jAEBEy5YAoRsVUqbJ84G3gaAsiREALw_wcB&gclsrc=aw.ds
I realise the munsen ring is 22mm and for 22mm pipe, used for plumbing. Would this still work? I am not sure if pipe used for plumbing is measured the same as electrical conduit, I.e does 22mm mean the diameter of the pipe (as it would in electrical conduit) or the diameter of the hole? I have a feeling these rings would not fit sungly and therefore not work.
2. https://www.electricaldirect.co.uk/...vmCi1fOLSbK9A6DUhD6zEeRSR2M6gy60aAlTUEALw_wcB
Cheers :)
An alternative might be to use brass for an improved aesthetic...pricey but nicey!
Many years ago we did an art gallery in London using brass conduit , but actually from what i was told and could tell from all the brass conduit and fittings is that they were not indeed Brass but a alloy metal that had been dipped / brushed to look like an Antique Brass.
It was so expensive just the antique brass conduit and fittings ran into the £100,000+ , that was before it was even fitted or wired.
They even had custom made plates and switches to match made by Wandsworth that also ran well over £100,000+
Some people just have too much money to spend...
Yes, some folk do seem to have money to burn, but the OP was about a small bit of conduit to a few accessories, and the owners are happy to pay the price, so it may be that the expensive option would suit them on this occasion....and it'd look very nice!
I was pretty sceptical when I first installed it, thought it might be a bit flimsy, but if you nip up the grub screws properly then its a pretty solid. I have used the ConLok system twice and on both occasions its been quick, and does the job.
I won't go back to threading unless its for an alteration of an already thread job
Interesting, how much quicker is it? I've never found the threading of the conduit to actually take all that long.
For me the biggest issue with steel conduit is the bender, getting it to and from site and then trying to find somewhere remotely close to where I'm working to set it up.
If there was a lightweight alternative for bending the conduit that removed the need to drag a hilmor type bender around then I'd certainly give Conlok a go as that would then make my life a heck of a lot easier.
HappyHippyDad
Supporter
Gloucestershire
United Kingdom
Which conduit holders for metal conduit?
HappyHippyDad,
nicebutdim,
TrueNAS JBOD Storage Server
