Which make of VDE sidecutters do you think are best? | Page 4 | on ElectriciansForums
Discuss Which make of VDE sidecutters do you think are best? in the Electrical Tools and Products area at ElectriciansForums.net
and what about these mickey mouse ones ?...................
I have some Knipex 95 18 165, which I suspect are similar, but without the spring and latch. Bought at this year's Sandown Elex. Very good.
I also have a pair of the stainless cutters (branded RS but likely to be Knipex). Had them for many years. Not nearly as robust, but just fine for snipping lighter cables.
don't buy them draper offset things. they're useless.
[ElectriciansForums.net] Which make of VDE sidecutters do you think are best?
Knipex for me! 160mm 95% of the time and the 200mm pair when needed for the 10mm cable!
Wheres that poll Shanky?
They just look all wrong dont they Tel!! I keep turning my head to the side!
just as i suspected then
the vde version above for more robust on site work , the stainless steel versions for panel wiring & workshop use.
Like andyelectric got the NWS multi cutter with the 3.5 mm screw cutter and grooves for striping 1.5 & 2.5 thought they were a bit gimmicky to begin but they now are my go to cutters
If I need a bit of grunt then it's ck shears
muscle power or not , i wouldnt be using side snips to cut anything bigger than 6mm t&e.
the clean slice of shears is whats needed on larger stranded conductors , experience tells me that ;-)
i wouldn't use then for second fixing bigger than 4mm but i would for first fixing
keep your old damaged snips , they can become what i call "demolition" snips , useful for cutting live cables , meter seals and any number of other naughty tasks.......;-)
anyways , im currently using these.......
stanley 7" high leverage vde sidecutters , bargin at around 13 notes.
however i am secretly whoring over these..........
knipex crops , not cheap. ;-)
OK my firm issued us with some of these, and within a couple of weeks they twisted out of shape, the edge dulled as I say it's with respect IMHO they are dross, waste of money, but hey ho what ever rocks yer boat.
I really rate the crops, they are superb, great for all types of cable. As you can see I have a couple of pairs!!
  • [ElectriciansForums.net] Which make of VDE sidecutters do you think are best?
Reply to Which make of VDE sidecutters do you think are best? in the Electrical Tools and Products area at ElectriciansForums.net
Which truly is the Number 1 Best Tile Adhesive Brand? Since 2007 Tilers Forums started an annual best tile adhesive Poll and sent it out to the...
Best Tile Adhesive Brand in 2011: Whats the best Wall / Floor Tile Adhesive Make? Which Tile Adhesive Did You Use Most During 2011? Please vote...
DHTiling
