which polarity | on ElectriciansForums
Discuss which polarity in the DIY Electrical Advice area at ElectriciansForums.net
V
voyager212
Hi everyone, I have a Bissell rechargeable floor sweeper and have misplaced charger, I have a universal ac/dc charger that you select your output voltage that I can use as temp, I have to plug the correct connector on the end and can have pos or neg polarity on the centre tip, problem is I don't know which polarity the sweeper centre pin is and don't want to damage by connecting wrong polarity, help please.
There is supposedly a recognised standard (sleeve is -ve and tip is +ve) but so many manufacturers don't follow it I'd strongly suggest you check with either a place that sells them or contact Bissell themselves and confirm.
Reply to which polarity in the DIY Electrical Advice area at ElectriciansForums.net
Depending on the specific battery you (intend to) buy, you might be able to just do Monster alternator -> LiFePo4 battery. The BMS for the fancy...
Probably a bit late for the OP, but there's a very easy option if a manual solution is OK. Rotary cam switches are just the ticket - but not the...
