Which Starter Contactor | Page 2 | on ElectriciansForums
Discuss Which Starter Contactor in the UK Electrical Forum area at ElectriciansForums.net
Scotland
Hi all I have a 3 hp single phase motor that only runs when you hold the button and stops when you release it. I am struggling to get my head around which contactor to get for it. Any help would be great.
You will have to install a stop button and change the wiring in the control circuit if you want it to latch on.
Only if it is safe to wire it like that.
The OP wants it to run as it is now, hold to run (or dead mans switch)
Reply to Which Starter Contactor in the UK Electrical Forum area at ElectriciansForums.net
Good point they may well have put the control through a main contact.
You only need to switch the lines and the contactor is rated per pole so for example a 16A four pole contactor would be fine.
