I
IshTing
Only ever used Fluke to be honest
Seperate instruments every time
Robin insulation/continuity
Robin Pfc/loop tester
Robin Rcd tester
No comment to make on all in one testers
At the least none that could be made without the word s--t in the comment![]()
UNG
I do honestly prefer single instruments
I was not alltogether serious,just stirring the pot a little![]()
i have the metrel mi3101
Metrel MI3101 EuroTest AT Pro Kit Installation Tester Kit
easy to use and the software is straight forward to download straight to the pc. i like the pro kit for the ring main testing 6 croc clips and press the button does all the cross tests for you without having to connect in going outgoing etc
We have both the The Metrel MI3101 EuroTest AT Pro and the MFT1552 and the metrel is far superior. We got 2 metrels last december then the megger in january, boss said he would take the megger wasnt long before he demanded a metrel back
You're having a laugh ain't you?
Way oo overcomplicated for a test meter in my opinion, and insulation resistances are dodgy if they've been sat in the cold overnight (I tested 3 on the same day, and for a 200Mohm load they were showing anything from 60-180Mohm)... Megger every time!
But different strokes for different folks I suppose...
