Which Test Kit is Best and Why
Which Test Kit Do You Use???
  • Total voters
    120
Megger 1552 IMO. Had it now for 3 years, bought it second hand. Sent it for repair under warranty just after buying it as the previous numpty (owner) had obviously trashed it somehow.
Been spot on ever since the repair and can't fault it.
Meggers must be like new cars in that some are solid units and others a little tempremental.
I've always been interested in why people choose different products etc. My testing is very basic hence I use a Robin KTS 1620. Bought it about 2 months ago second hand, recently calibrated. It does the 4 tests I need it for anyway! The megger 1552, don't know much about them really, I understand they store all the test and can print out direct with them but is there anything else they do?
Is personal choice down to ease of use / familiarity / cost? I'll keep plodding along with my yellow brick for the time being! ;)
The Megger 1552 won't do any of the storing of data or form filling for you.
Its just a standard multi function, with what I think are basic, simple easy to understand dials for operation.
I have Megger 1553, bought it about one year ago, never had a problem, very easy to use. I made my cross check device with six different type of resistors (from 0.05 ohm to 1 Mohm) and check it each month and keep the results in logbook (no need calibration any more). Always accurate till now.
Surely you still need a calibration certificate, or is that a way round it?
YEs, you will still need to have it calibrated yearly. Don't know of any scheme provider who allow you just to use the checkbox sort of thing in place of calibration.
just a little side track.anybody had dealings with On Site Calibration Services. they offer MFT cal. at £57.50, fully traceable and they come to you.
If you're only padding about on domestic then socket and see perfect.....reasonably priced,light weight,take a fair amount of punishment,easy to read use etc.
For commercial it would be advised to go for a MFT as its saves time when you can remember where on the job you left your loop meter/rcd tester plugged in!!!!!!!!!!!!!
Megger 1552 easy to use and quick results , a doddle after using 3 seperate instruments i recommed it, safe all
While I've always used Fluke multimeters in my electronics work (I tried the AVO digital equivalent and hated it), I chose a Megger MFT1553 for electrical testing.
I had done some research prior to committing myself, and I'm pleased with it.
I find it's very easy to use.
The only thing that lets them down is the quality of the individual test probes and the matching croc clips.
I've not had mine so long, but reckon I'll be needing to replace those leads within a year, maybe months?
The croc clips don't have that much grip, and quite easily come off the terminal under test.
The little ridge that allows the croc clip to "snap" into place on the probe wears, so they can be easily pulled off.
Also the barrelled spring part of the test probe (which connects the croc clip to the probe) weakens with use and contact becomes poor.
On the other hand, the big red control probe and the 13-Amp plug test lead are well made.
Simon.
What multi test kit would you suggest for a new start? Simple to use and relatively cheap.Have recently went out on my own and get a firm in to do all my testing but will be looking to buy my own kit soon.
And what about PAT testing equipment? Going to try and get into that market soon aswell.
At the end of the day, whatever you choose, look after it, use it often, its a real money machine! All I do is inspection and testing and I do very well on it. Good luck everyone!
The Code of Practice for pat testing says, "Generally, portable appliance test instruments offer the most convenient means of providing the required test facilities, but this does not preclude the use of suitable individual general test instruments".
Why spend hundreds or even thousands on another meter, I made a variety of leads that plug into my megger (or any other) tester with a selection of connectors, 3 pin and bayonet and carry them in a small bag. After all the main tests are continuity, insulation resistance and earth bond. Do these not sound familiar?
I have ben told several times by my NICEIC inspector chappy, that as long as i have a record of resisters used and results of the tests done on a montly bases; also i could use my house supply for RCD checking etc. Then i wouldn't need a yearly calibration certificate.
He also said i should only get the MFT calibrated if the results change from one month to the last.
Although, it is quite annoying to do this. So i use my old boss's check box Kewtech fastcheck FC1000.
I've had a Megger 1552 for the past few years, excellent machine, although just starting to have to hold the rotary switches in place to ensure it doesn't move fractionally and go blank.....Very annoying:mad:
Looking at the new megger 1730 quite expensive but if as good as 1552 will probably buy it.
acat,
Dan,
