Which Wago is best 221 or 773 | on ElectriciansForums
Discuss Which Wago is best 221 or 773 in the UK Electrical Forum area at ElectriciansForums.net
Bristol
I’ve been using Hager junction boxes for ever .all been specified and now I looking for alternatives
Wago’s 773 or 221 .
Any preferences , been racking my brains etc
That depends what you are connecting. If its solid core and coarse stranded conductors for permanent connections then the 773 are good.
If you need to connect stranded conductors, make temporary connections then the 221 are suitable.
Reply to Which Wago is best 221 or 773 in the UK Electrical Forum area at ElectriciansForums.net
Cancel this...in my Wago fixing tin in the van it's still the 2273-203. In my stores it's 2773-403, so I've not been using them yet. They are a...
Thanks a lot for the quick reply. I already have a good number of the 32A single gang connectors so I'll be using those on each individual wire...
Thank you, it is always good to hear another suggestion :)
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3
https://cdn.cityandguilds.com/productdocuments/building_services_industry/electrical_installation/2330/additional_documents/2330_faqs_v1.pdf It...
