GETWIRED
Just seeing peoples opinions on the whiska Quixx glands for tails? Bad practice to use them without tails clamps within CU?
Discuss Whiska Quixx in the UK Electrical Forum area at ElectriciansForums.net
Yes, the way I was taught, you'll find that the settling effect is much less but still need a wiggle and a 5 minute tighten. Good practice. Haven't heard the single strand use @westward10 - do you mean take a single long strand and spiral it around the termination length to act as a pin ferrule type termination?I flatten them out with pliers to the shape of the cage clamp.
That is correct, they never budge.Yes, the way I was taught, you'll find that the settling effect is much less but still need a wiggle and a 5 minute tighten. Good practice. Haven't heard the single strand use @westward10 - do you mean take a single long strand and spiral it around the termination length to act as a pin ferrule type termination?
Best practice as used by DNO linesmen and jointersFlatten them with pliers, use a hammer is this a joke.
No wonder I get so many power cuts.Best practice as used by DNO linesmen and jointers
Reply to Whiska Quixx in the UK Electrical Forum area at ElectriciansForums.net
