Whiska Quixx | Page 3 | on ElectriciansForums
Discuss Whiska Quixx in the UK Electrical Forum area at ElectriciansForums.net
Manchester
Just seeing peoples opinions on the whiska Quixx glands for tails? Bad practice to use them without tails clamps within CU?
It stops the copper strands shifting.
I would suggest that binding the strands like this would be a good method where the terminal uses one or more screws bearing directly on the core, as it would protect the strands from damage, rather in the fashion of a bootlace terminal. On a cage clamp type terminal, I don't think it would offer any particular advantage over settling the strands properly into the terminal.
Thanks for the Griploc link Mid via Lee!
I was about to order around 10 of the Sprint version, which would be considerably more expensive. Also I like the fact the 25/16mm gland is 32mm, as can use my cone cutter which I find quicker and neater than a hole saw.
I disagree but each to his own.
Reply to Whiska Quixx in the UK Electrical Forum area at ElectriciansForums.net
Ok I’ll try this when I’m down
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
