who to ring | on ElectriciansForums
Discuss who to ring in the Australia area at ElectriciansForums.net
Hi all,
Who would i contact if i'm getting a ZE which is higher than values accepted?
ZE on tns 0.38
customer is with N Power but tried them earlier and they didn't know what i was talking about. wondered if there is a special number to call or anything
thanks
ahh right! i thought it was 0.08! thanks guys.
still could do with contacting though, incoming earth is in a nasty choc block so was hoping they could replace this.
They have sent a letter to customer to say they want to come and upgrade meter so could do that at the same time.
cheers
Yes the thing is the meter fixers are usually just that---i.e. meter fixers -not Sparks...you will need to arrange for the DNO operatives to sort that one out.
sparkylad
Reply to who to ring in the Australia area at ElectriciansForums.net
I think I might be tempted to test this theory, if it can be done without causing danger to anyone.
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
