Why 2 hob ratings per ring | Page 2 | on ElectriciansForums
Discuss Why 2 hob ratings per ring in the UK Electrical Forum area at ElectriciansForums.net
See Table 4A2 Number 40. Method C does not define a cable within a void.
from 4A2 no.40. ref. B applies when V < 20d, V being the height of the void, and d being the diameter of the cable. between floors, V > 20d. (unless its a very shallow void, in a house it's generally 300mm (ish))
Reply to Why 2 hob ratings per ring in the UK Electrical Forum area at ElectriciansForums.net
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
