C
Craigie
I would be grateful for thoughts on the benefits of holding the C&G 2391 qualification.
Discuss Why 2391? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I would say that you need it to call yourself a fully qualified electrician.
Hi mate I hold the 2391
unless required to you dont need it,
to test anything COMPETANCY is the key word in the regs
as long as you deem yourself competant and you know what your doing then there is NO NEED for the 2391 to tell you ,
you can do it, its your call
obviously be responsible and dont set your test meter to resistance when testing mains voltage and you should be fine
if it goes bang your not COMPETANT and will need to do the 2391
its pretty much impossible to pass 2391 without experience anyway hence why the pass rate is so low nationwide, its recommended that once gaining 2330 level 3 and 17th you get atleast two years experience before even thinking about sitting the 2391 exam but i guess this is what makes it worth having because any old tom dick and harry cant just turn up and pass it, only real electricians can gain this qualification!
Reply to Why 2391? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
