UK Why are new build prices so bad?
Hi , I've recently started on a new build site in essex, self employed sub contracting for a colchester company for which I have done work for 3 years .recently I've started to take the prices as a personal insult. A 3 bed house 1st fix including 2x data, 2x tv points 3x bt around 16 x sockets , 2 zone combi heating with weather compensater, oven and separate hob,3x smokes 1x heat , 1x co detectors, 4x fans, shaver socket, 10xlights and switches and 2x outside lights and garage supply is £250 which is around £600 pound less than the plumbers 1st fix price! How can anyone do a good job for that? And apart from walk off site ( which I have done) what can be done? And why are electricians the worse paid trade on new build sites?oh and the 2nd fix price was £10 less
I’ve been on quite a few developments where Labourers do all the cable pulls , boxes , noggins etc
the electricians / mates only come along on second fix stage And then someone else later to do the testing.
probably the last few new jobs were like that ...
It's a shocking indictment of today's homes. but go to an average new estate and you will get crap for your money. I cannot understand why folks part with so much money for so little...but then again, they don't know what goes on. The shiny kitchens and bathrooms are all they see.
Reason's are simple.... 1) younger house buyers haven't got a first clue of what they're looking at (consider half the EICR and DIY posts we see on here!) 2) beggars choice - 'proper' houses just aren't available and affordable 3) A new build hamster cage is luxury at £900 month mortgage by comparison to the £1k a month rent on a mouldy dilapidated 1960's (or whatever the maths is)
labourers at £10/hour.mates at £15. then a qualified spark to test on price (as he's on £40/hour).. 30 minutes allowed per house. EIC better used as bog paper.
with the price of bog paper these days, I might start using my old test pad instead ...
I know standards have dropped, but have a look at some of the 2nd hand houses that are available. Damp, dry rot, no cavity walls, no RCDs, rubber cable,.lead pipes, solid floors with no air flow, etc. Etc. At least a new build will be dry and cheaper to keep warm. There's good and bad in both camps.
i'd rather have a damp, cold house made of solid bricks with proper plaster on the walls, not cardborard coated dust stuck on by some dry wall oiks. at leastyou can improve the old houses without demolishing them.
I know quite a few people with older houses, and they always seem to be fighting against them. And does it really matter that internal walls are studs rather than brick? Or that they use trusses instead of separate beams?
Most new builds in NI are block/block or block/brick cavity walled, with all internal walls floated out in plaster - downstairs walls solid and studding upstairs.
We do have timber framed construction, but nowhere near as common. Never seen dot and dab.
Has anybody actually seen the wageslip or yearly accounts of these so called high earners.
It's easy to talk B*llocks.
He may earn 250 - 300 a day but is that every day or occasionally, how many hours a day do they work and what do they earn on the rest of the days / months / years.
My thinking too.
Its all good and well earning £300 per day but is that every day every week? or occasional?
I can earn £300-350 a day often but then you have days where there is lots of small bits and admin where you earn £160 but averages out well overall
roof trusses are the spawn of Satan. how are you supposed to store anything up there, unless you have triangular boxes.
