Why do lamps blowing trip RCDs? | Page 2 | on ElectriciansForums
Discuss Why do lamps blowing trip RCDs? in the UK Electrical Forum area at ElectriciansForums.net
N
NickD
...cos if the lamp is in effect Class II with connections only to L and N (Edison screw; standard bayonet cap in unearthed pendant or batten), you would naively think there is no way the L and N can be in imbalance. But still the RCD trips. Definitely talking RCD trips here not MCB. I've seen mention of surge current spikes but never got to the bottom of it. Googling just seems to bring back forum postings that don't really answer the question. Cheers.
The rcd is a finely balanced unit relying on a very small imbalance between L and N ...when a filament lamp blows sometimes it leaves an ionised path through the gas atoms which act like a short circuit although it does collapse fast it can sometimes exceed the time/curve graph of the mcb.... as with any short circuit 1000's of amps may flow and the magnetic field associated with this is very large and can saturated the fine balancing fields of the rcd causing it to trip.
I wish there was something more than a 'like' I could give this!
If you want to get technical about it and correct me if I'm wrong, current flows from positive / Line to negative / Neuteal and to complicate it the electrons flow from negative to positive, but you should know that.
ah, but do the electrons know it? could be sometime they'll find out that for years they've been flowing the wrong way, then all become heterosexual.
Oer missus! lol
Now, now, HHD we will have not of that kind of talk on here, this is a respectable forum I will have you know! lol
Now, you say that but others seem to suggest otherwise...
I didn't post it on here for people like you to have something to watch in your chair while jacking off to a forum
Reply to Why do lamps blowing trip RCDs? in the UK Electrical Forum area at ElectriciansForums.net
