why do smokes randomly go off?? | on ElectriciansForums
Discuss why do smokes randomly go off?? in the Talk Electrician area at ElectriciansForums.net
usually when the house catches fire :)
is it wired from another circuit or on its own?
dust getting into the unit from above?
battery dying?
Hi jenions,
Does depend on the type of smoke alarm. Basically they are particle detectors and there is a threshold limit. Typically ionisation smoke alarms react to tiny particles from fast flaming fires and optical larger particles from slow smouldering fires.
They can be affected by steam or anything that produces particles which can enter the sensing chamber. Dust can be an issue as other stuff like that. Positioning is very important.
Electrical interference may be an issue from items that dont comply with the EMCregs etc.
Best advice, keep them clean and bagged if installing on new builds until the works are finished.
Hope this helps a bit,
best wishes
Rex
i think the reason they are going off is because you have connected them incorrectly,the first detector requires a supply ?but the yellow cable is for interconnection of other smoke alarms (its not an earth)then 3 core between other smoke alarms live neutral and monitoring colour yellow otherwise you get an in balance to earth which trips your rcd
Can I have some of whatever you've been smoking please?
I have no idea at all, what any of the above has to do with smoke detectors activating spuriously, which is what the OP wanted to know about -
Not only that, if you are wiring anything using yellow sheathed wires in this day and age, you need to go get your qualifications updated FAST.
3 and Earth is Brown, Black, and Grey - and has been for a long while now.
As for earth faults - very unlikely on any BS smoke detector as the earth terminal, if provided is NOT electrically connected to any part of the detector, and earth is used purely for protection on the cable.
While we're on the subject, there are a number of reasons domestic (i.e. interlinked, or non interlinked) mains smoke detectors will activate for no apparent reason.
Number one reason is likely to be the fact you've installed an ionisation type smoke detector in a draught corridor.
Number two reason - back up battery is kerput! Silly little 9V dry batteries should be replaced annually, whatever the manufacturer says - if the detector has been tested at all, that battery has been used, and will lose charge. And the detector *should* have been tested, after all.
Number three reason - build up of dust in OPTICAL type detectors. It's akin to myopia in humans, and means the detector cannot "see" properly - and thinks the dust is a smoke build up.
Number four reason - incorrect choice of detector for environment - e.g. similar to one, but down to things like toast, cooking, burning, heavy smoking.
You have to remember that an optical sensor uses an led and receiver, and any dust, particles will set it off... You just need a particle large enough to reflect the light onto the receiver...
[ElectriciansForums.net] why do smokes randomly go off??
Reply to why do smokes randomly go off?? in the Talk Electrician area at ElectriciansForums.net
This is it though…. To put one following the letter of the law, so to speak… would be a smoke in the hallway outside the bedroom door… then a heat...
Hi all! This weekend we have an offer on 8 of our most popular Smoke, Heat & CO alarms from trusted brands! Don't wait too long as these offers...
