W
WilcoxElec
In France we use Bipolar MCBs everywhere and one advantage is that a circuit can be properly isolated even if Madam has a load in the washing machine while you are doing stuff on another circuit. I have come across cases where a UK style consumer unit has been used in a DIY renovation – and I was replacing some circuits and moving them to a French board . I opened an MCB on the UK unit, and at some point I caused the RCD (DDR !) at the head of the unit to open by accidently touching the Neutral to the Earth – - there was load on the other circuits – and the neutrals are all together in the consumer unit. At the time I supposed that this probably couldn't happen with the TN schema used in the UK, but – thinking about it now – I realise that – yes it would. So – my silly question is "why do consumer units have monopolar MCBs?" They must be cheaper – and of course one should switch off everything at the mains always --- but there does seem to be an advantage to the French set up (if done properly) - if cutting off everything is really really inconvenient.
Please excuse another silly question , just trying to get the number of posts I need for the next level LOL (and avoid doing the paper work I should be doing) :juggle2: .....
