"Why do we bother" rant ................... | Page 2 | on ElectriciansForums
Discuss "Why do we bother" rant ................... in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Knowing whether they have been had or not can only be ascertained if we know the initial fault and the works required to remedy it.
Apparently the initial fault was swapped polarity on 4 upstairs sockets.
Not sure what work was carried out to fix the problem.
duplicate post
I'm more curious why the electricians say they don't need a cert...
Ok, please excuse my ignorance now but what should the general public ask for when they get an electrician to do some work?
I know they don't need to be part of a scheme.
So what would we ask to see?
Stroma insisted on giving me a photo ID card .................. not sure why, its collecting dust in a drawer now.
Some clients want cheap, as possible ................ nothing else matters.....
Does sound like theyve been had from the info we've got.
A simple plug tester & a walk around checking would have found them quickly.
Sorry mate. I've just got what you were getting at.. It's just me and my rubbish explanation.
Apparently the wire colours to the sockets were correct but the polarity was not. Somewhere the polarity had been changed. That's why they had the floor boards up.
A fault with a RFC (or any circuit for that matter) can take some time to locate, unless you strike lucky, and certainly if a diy'er has been let loose with JB's a plenty under the floors. I'm not one of those that are emphatic that a certificate should be provided, every time you cross the threshold, but to fix a fault like this, would normally involve some testing, and certainly to prove it's all in order to re-energise. So I see no reason not to provide one, only other than what Murdoch was suggesting.
If you friend is being a bit cagey, perhaps he feels a bit embarrassed, if he feels he's been had over? Difficult to tell from here, as Westward suggested.
That's why Ive been more concerned with them getting a cert.
Update:
This is what they said they have done:
We've basically put a new supply and rcbo in and connected it to the house sockets which are now fault free. The original cable still has a fault on it. It has no load so it should be ok until you do the garage at which point it might be possible to trace it back and find the actual fault location. Anyway we've sorted it were others did not.
Reply to "Why do we bother" rant ................... in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
You need some silicon oil spray
Glad to hear you approve @Moley
    • Winner
