N
NickD
At least for the low ohms measurement range anyway. It'd be great to be able to quickly set a delay period between the pressing of the Test button then the actual performance of the test, for those awkward tests where you can't hold the probes in place and press the Test button at the same time. So for example set ten second delay, press Test button, take up to ten seconds to get the probes on, wait, test executes, happy days.
It's not as if the meter would require extra electronics or more than about a dozen lines of code in the firmware to do it.
I can see why this is a no-no on the scarier test functions (1000V up yer backside when you least expected it), but low ohms range...24V test voltage? Maybe it's still too risky for some reason not obvious to me.
Probably going to get slagged now for not having done the Yoga training that comes as part of a proper apprenticeship which means you are always able to press the test button with your toe.
