Why gas boiler want fire using solar hybrid inverter | on ElectriciansForums
Discuss Why gas boiler want fire using solar hybrid inverter in the DIY Electrical Advice area at ElectriciansForums.net
Kincius
London
Hi my name is Gintas I connected solar hybrid inverter to my house ring supply and it work very well everything except the gas boiler for on demand hot water, the radiator heating works fine any idea why boiler want fire when I open the tap?
Flame detector
Earthing system
This is a complex issue and you need to get it installed correctly for your own safety.
I believe a solar inverter or any other microgeneration device needs to be on it's own circuit, not sharing a circuit with any loads.
Not sure that's relevant to boiler but it does indicate that other issues may have been missed in the install.
Hopefully there's an AC isolator between inverter and house wiring. How does the boiler work when that's switched off?
Regarding the boiler itself, does hot water require a permanent live, not needed for heating?
Reply to Why gas boiler want fire using solar hybrid inverter in the DIY Electrical Advice area at ElectriciansForums.net
A
Gas Boiler and Radiator Replacement I bought my house 31 years ago with its 8mm and 10mm micro central heating pipework and existing radiators...
Alan Wright
A
J
Have my water pipes been plumbed the wrong way? Good morning, I recently had an extension, new bathroom and new en-suite fitted. Prior to the...
jennys07
J
