1shortcircuit
I believed that the rented property that I currently reside in may not be up to spec on the Electricity side of things.
Anyway, I decide to check on the .gov website about landlords and found this
PS My course and work experience are going brilliantly
Is anyone aware of any regulations that state rented accommodation should comply with the latest regs? Or is it possible to attack this from another angle?
The property in question is using a Wylex fuse board that is not using RCD protection but I have found GAS and WATER bonding but it looks closer to 6mm than 10mm?
Many Thanks to those who can offer any help
So I did another search and found thisElectrical safety
By law, your landlord must make sure that the electrical system and any electrical appliances supplied with the let, like washing machines and toasters, are safe to use. Your landlord must make sure electrical wiring and appliances are maintained in a safe condition for the length of the tenancy.
If your landlord supplies new appliances, he or she should also provide any accompanying instruction booklets.
And some of you guys believe that it's the influx of short course electricians to blame for the lack of workGas
The landlord must comply with current Gas Safety (Installation and Use) Regulations (which cover Liquid Propane Gas installations) by:
(Source - Gas Safety (Installation and Use) Regulations 1998)
- Arranging for annual gas safety checks to be completed by a GAS SAFE registered contractor and a gas safety certificate obtained
- Ensuring all servicing, repairs and replacements are completed by a GAS SAFE registered contractor
- Providing tenants with a copy of the servicing certificate
- Retaining records of safety checks for at least two years
