This is an RSS feed of thread: Why is my pumped shower suddenly slow in starting?
Content of the thread: Not been on here for ages, got a lot of help when I installed my bathroom some years ago. Everything went fine until I had to replace the shower mixer valve recently. The old one had started to get stiff to turn, so I fitted an identical unit to make the job easy - it's a cheap, minimalist "Harrison Mode" unit from a well known victorian supplier. All went well, until I came back from 2 weeks away, and I now find there is a delay when I turn the shower on - was a second or two, now up to 5 seconds before the pump starts and the water starts to flow. It's fed from a low-level H&C pump and has worked fine for over 10 years. Any ideas?
Why is my pumped shower suddenly slow in starting? to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
