why is there no earth | Page 2 | on ElectriciansForums
Discuss why is there no earth in the UK Electrical Forum area at ElectriciansForums.net
L
lofts
Im waiting for acceptance in the training forums but whilst I do I have a question. Ive always been told to earth things for example sockets that are not standard plastic but shinny nickel, I know you can get away with just using the lugs on a back box and the screws which are used to pull the socket face plate tight to the metal back box if the lugs are fixed however I still but an earth cable from the earth terminal on this back box to the earth terminal on the back of the socket juse because its good practice imo.
Whats baffling me is these new spotlights Ive just got from screwfix, they are Robus and the instructions say DO NOT EARTH! my initial thoughts were that this was a mistake but upon further investigation there is no earth terminal at te fitting just a Live and Neutral. My question is why dont the have an earth terminal as surely this is wrong. They are chrome so surely an earth is needed. Tempted to ring Rombus up and ask why but thought I would try here first as one of you guys will probably no why?
cheers
If it was you would you just cut the cpc's of or should I just choc block them for good pactice.
From memory 412.2.3.2 essentially says that you have to run and terminate a protective conductor to each accessory. I can't remember the exact wording but this is not just good practice, it is a requirement. That is presuming the installation is not under the supervision of someone who will ensure that these fittings will never be changed to class 1 pieces of equipment.
means of earthing (CPC) at every point on an installation (initial verification)....or words to that effect damion..
Switches maybe, but I hope thats not how your terminating sockets...!?
Reply to why is there no earth in the UK Electrical Forum area at ElectriciansForums.net
Ok I’ll try this when I’m down
"A catalogue of errors" would be the appropriate phrase here and I agree with Avo and James that HSE need to be involved rather than this forum...
