Why neutral? (And why 20 characters in a thread title)? | Page 2 | on ElectriciansForums
Discuss Why neutral? (And why 20 characters in a thread title)? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Has this always been the case that the neutral seems to be more susceptible than a live, or is it a more modern trend?
I'm just thinking that maybe the increasing use of electronics which can create harmonic neutral currents could somehow be related?
I was thinking along the same lines, but I'm thinking this would only really apply in three phase systems which is why half size neutrals are becoming a thing of the past.
Once upon a time... (before the days of moulded plugs) when I worked as a TV/Video Tech. when checking the plug connections on equipment with intermittent power, it was invariably the neutral that was loose.
i notice it's the neutral at the high load items like showers and cookers. Generally it's a loose connection on the load side, although a decent one was a loose neutral at the actual shower and had burnt the pullcord out as well.
Double sockets tends to be the line that's loose & burnt out.
Increased harmonics from electronic power supplies, especially in the triplen range could be the cause of higher neutral termination failures. Also poor quality neutral bars with single screw terminations and almost no brass content probably don't help either.
Reply to Why neutral? (And why 20 characters in a thread title)? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Only the N side of the lamp would be at 0v if you went further along the element the voltage would rise.
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
