Oldtimer is basically correct, if all socket circuits were of the radial design, UK CU's would be need to have more way's on each side of the dual RCD's and more expensive RCBO's on a straight CU.
If the ring circuit is dropped in favour of radial circuits then you can bet your soul, that they will introduce a socket outlet plug system designed for use with radial circuits like the German/French systems, then you can kiss your 4mm radials goodbye!!
Traditional bull**** as you put it, is well based on tried and tested circuit design, nothing wrong with your beloved belief in radial circuits, but by the same token there is absolutley nothing wrong with a ring circuit either. Generally find it's mainly the electrical trainee's brigade that don't like rings, because they haven't a clue how to test or fault find them.
