UK Why one LED driver is using less Wattage
Welcome, I have two desks and each of them have the same setup, in terms of the amount of LED strips, the amount of LEDs (I counted), but only different is LED Driver. So:
Setup 1:
  • LED Driver (Ecopac 24W IP67 Rated LED Driver (EPV-24 Series)) - 24V
  • 4 LED strips
  • Uses 1.3W
Setup 2:
  • LED Driver (Mean Well NPF-40-24 (NPF-40 Series)) - 24V
  • 4 LED strips (Same ones like Setup 1)
  • Uses 0.7W
The efficiency mentioned in Setup 1 for LED driver is about 82%, whereas Setup 2 LED Driver 88%, I don't think that's a huge contributing factor?
Could someone educate me why there is such a big difference in energy use between these two? Almost halved!
Would that be surprising to anyone? Should I have done anything differently in terms of testing? I measured from the AC socket directly
Setup 1:
  • 4 LED strips
  • Uses 1.3W
Setup 2:
  • Uses 0.7W
Try testing direct current using a dc multi metre capable of measuring current .with led strips it's not a case of placing your multi metre directly on dc terminals there is some additional disconnection to do of led connectors the current will need to be meusured in series. I assume from your post you have some back ground testing knowledge .
You mention meanwell depending on led stripps and length using a parrallel method to connect them would reduce volt drop and according to ohms law v=ir .meanwell are very good drivers /controllers
