Why prices for different colour junction box | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss Why prices for different colour junction box in the UK Electrical Forum area at ElectriciansForums.net
Reg.526.3 Every connection shall be accessible for inspection, testing & maintenance...
I know that, but that bit if wiring was already on connectors wrapped in tape. Anyway I went down it's lighting cables near a spot, so it is assesible. Put them in wago connections and Chuck box, so it can be pulled through the spot hole.
If it was not accessible I would prefer to use junction box. I don't feel yet, wago has been around long enough for me to trust them.
Bloody hell, never knew this. I like using 5A junction boxes for spot lights.
So what is used for spot lights.
for spotlights you can use screw terminal junction boxes...You still can’t use the small junction boxes you’ve linked to for downlights because there is no strain relief . For downlights that you cant loop in and out of then you could use these Google Shopping - Product not found - https://www.google.com/shopping/product/1?q=hager+j501&safe=strict&client=safari&sa=X&hl=en-dz&biw=320&bih=454&tbs=vw:l,ss:53&prmd=simvn&prds=num:1,epd:5718562672038894077,paur:ClkAsKraXwwlQpciS9k11gYF510zIW6FMhq69hGjegV8lZ6b975okegQwahNBRJhBZNkUQOj02JO--9jQ7TsB2T6j1wow6vwWYsucrmt7LTc3cwqYnTICbULThIZAFPVH71wWdFXVMLrPIuokX7b_twLTWmyoA,prmr:1,pid:5718562672038894077,cs:1&ved=0ahUKEwj5zaP6n5PeAhXqAcAKHWCyCckQgjYI1AQ the reason you can use these is because they have a strain relief clamp and are accessible by pulling the down light out. Anything that’s not accessible then you need to use something like the J803 linked to earlier because they are labeled MF which is maintenance free. They are MF because of the push fit, constant pressure terminals.
The JB’s you’ve linked to are only really any good where they are accessible, can be screwed down and where you can clip the cables that enter them giving the required strain relief...One example could be for under cupboard lighting.
Wagos have been around for decades. I used to come back from Germany with my suitcase full of them before they were on sale here. Also the continental style boxes, which I much prefer to the British Wagobox but are not certified MF because you have to provide your own glands if required.
The answer to your original question may be pigmentation. A lot of plastics are clear/white in the natural state, with other colours requiring pigment. Some of the additional cost could be due to pigments used to make the boxes black.
Just a point... in my opinion, it's only accessible if you know it's there, so if you can't see it when the job is finished I would consider it inaccessible. For anything else go for a maintenance free option like a Wagobox or the Hager boxes that have already been mentioned.
I agree with sparkychick, it's the pigmentation sometimes. Years ago black cable-ties were quite noticeably dearer than the "natural" ones, and some still are, albeit a quick glance at a few suppliers show very little difference now, if any. Indeed, screwfix are listing 55 x 9mm packs of 100 at £1 more for the natural ones...
but I expect demand drives the prices more, nowadays.
Reply to Why prices for different colour junction box in the UK Electrical Forum area at ElectriciansForums.net
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
It might be ok
Recommended Sponsor News
Hi everyone,
