Why TN-C-S? | on ElectriciansForums
Discuss Why TN-C-S? in the UK Electrical Forum area at ElectriciansForums.net
Is it definitely cheaper than TT? I have no idea and have never give it much thought TBH. It was discussed briefly on the C&G2330 but can't remember much from back then!
I recently spoke with a dno engineer who was investigating a tns with a 10 ohm Zs, he seemed to think tncs was lazy and that tns being too costly to maintain, that they would no longer supply an Earth and spec a tt. Nice chap he had to dig up the road until they found the cable, because they had no idea where the joint was, even though they had fixed it once 8 odd years ago!
Nice to see they keep all their maps up to date eh! I can understand why TNS would be more costly to upkeep, but can't quite grasp why so with TNCS. TNCS is excellent for cct Zs's and as long as the neutral doesn't get lost then is a good arrangement. Lazy possibly, but TT lazier!
It is cheaper to follow one standard system than three different ones.
Very few new distributing mains are going to be installed overhead, new housing estates etc will have underground distributions.
So the one system they select will have to be suitable for underground use.
To install TT underground would be more expensive as you would need an earthed armour around four cores whereas TNCS needs only three cores with a combined earth/neutral outer conductor.
I disagree, why would the armor have to be earthed for TT? The same cable that does TN-C-S can do a TT supply.
Went to change a CCU a few months ago and got a Ze of 13 ohms on a Tns system. Called UKPN, they came round an hour later. The guy was umming and arring about having to dig up the road, then he said 'do you want me to see if you're eligible for tncs?' I said okay then. He just did an impedance test between L and N at the service head which came up at 0.13. I gave him a bit of 16mm G/Y and an earth block for him to screw onto the back board and that was it. He even renewed the main fuse and gave me a few meter seals. Last thing he said was 'just make sure the main bonding complies'.
Seriously? It's one of the most basic principles we follow for safely burying cables, surround it with an earthed metal covering so that any conductive object penetrating it becomes earthed before hitting any live conductor
Yes, seriously, though I am partly at fault for misinterpreting what you said as 4 cores meaning no cover:
However Im still trying to wrap my mind around why TT needs 4 core and TN-C-S only needs 3 cores. Both TT and TN-C-S will do fine with 3 phases plus a neutral.
Also, since we touched the subject, if something does pierce the cable, do the DNOs have something to clear the fault or at least fast enough? Im aware of places like Australia where an LV cable fault results in major fireworks as the secondaries are unfused with the primaries being fused at 2x the trafo's primary full load current.
[ElectriciansForums.net] Why TN-C-S?
Reply to Why TN-C-S? in the UK Electrical Forum area at ElectriciansForums.net
Yes, for example: https://kingsmillindustries.com/product/km2-20-10-sc/ However, the reality is the L-N-E style are far more useful in general as...
M
S-traps self Syphoning I watched a video and it went in about S-traps self spyhoning after discharge and said they were band in the USA. This...
Matt0029
M
