Discuss Why use 12v downlights in the UK Electrical Forum area at ElectriciansForums.net
cos the EU's gonna get rid of them in 2018; EU delays ban on halogen bulbs | EurActiv,
IMO it's unacceptable to have so much variation in one row of lights.
Lucien - could you elaborate on "12V halogen is generally better than 230V halogen - the lamps are more efficient, more durable and have higher colour temp." I'm sure many would be interested.
They were all the same type - MR16. Maybe different makes, maybe different transformers, almost certainly different ages, maybe even different wattages, maybe different amounts of pressure, dirt or corrosion on the silly pin connections, and they all look very different.Bit what caused the differences? Did it look like that when it was first installed.
If someone has changed the lamps with different types then it is hardly the fault of the lamp is it?
I just didn't understand how you get more lumens per watt from 12v lamps, and what is different that they last longer.?What kind if elaboration are you looking for?
They are more efficient as you get more lumens per circuit watt
They are more durable as they last longer and can take a bit more rough treatment
And the colour temp speaks for itself, it higher therefore a cleaner/whiter light
Reply to Why use 12v downlights in the UK Electrical Forum area at ElectriciansForums.net
