Why would a relay be fitted to a heating system | on ElectriciansForums
Discuss Why would a relay be fitted to a heating system in the UK Electrical Forum area at ElectriciansForums.net
Dorset
I have been asked to rectify a fault on a heating system, I have done lots of heating systems but never one with a relay. The heating engineer told me it was an s-plan, but it has a pump for the hot water as well as the heating and also has a "hot water off" wired to the timer.
The problem I have is that when the hot water is on and you switch the heating on, the hot water pump cuts out. The system used to work but recently failed. I'm assuming its the relay
Any ideas?
Any ideas?
Have you tested anything? What is the relay connected to? Assume nothing!
I am thinking you have 2 pumps , 1 for heating and 1 for hot water wired into their own 2 port valves , is that right , and controlled by 2 channel programmer , you say their is also a hot water off return to the programmer , How is the relay bringing in the pumps , it could be that is the way it was planned , the relay was selecting either 1 pump or the other , with this in mind it could be that the heating zone is so large in relation to the boiler output that this is how it is, please supply more info if you can.....
Not sure , can you trace and draw it out then post it , it should be possible , just need to see a plan / drawing , you have 2 pumps here using the same boiler you see and if the boiler has return over run then it can only apply to 1 at a time , get a drawing done and we'll have a look mate.....
Reply to Why would a relay be fitted to a heating system in the UK Electrical Forum area at ElectriciansForums.net
I
Baxi system boiler and Opentherm Hello Does anyone know if its possible to connect an Opentherm thermostat such as a Nest to a Baxi 800 System...
Ian777
I
Anyone plumb a DIY hot tub? I bought a used acrylic hot tub shell that I plan to sink into the ground in the backyard. The plan is to heat it with...
siricosm
