Why would a relay be fitted to a heating system | Page 2 | on ElectriciansForums
Discuss Why would a relay be fitted to a heating system in the UK Electrical Forum area at ElectriciansForums.net
Dorset
I have been asked to rectify a fault on a heating system, I have done lots of heating systems but never one with a relay. The heating engineer told me it was an s-plan, but it has a pump for the hot water as well as the heating and also has a "hot water off" wired to the timer.
The problem I have is that when the hot water is on and you switch the heating on, the hot water pump cuts out. The system used to work but recently failed. I'm assuming its the relay
Any ideas?
You have 2 systems in effect , working from 1 boiler , I think that 1 off the pumps would have to be removed and flow from the boiler fed through just 1 pump then split to feed the 2x 2 port valves , so plumbing would need to be altered , also check to see if both2 port valves are spring return ,( usually are ) then wire the system as a S plan as normal .
So some plumbing is involved , Simply return it back to an S plan system ......
Another thought , are the 2 pumps different sizes, it could be that the pump required for the heating circuit is too highly rated for the hot water circuit and has a smaller pump for the hot water
I think you're barking up the wrong tree here mate. The clue is in the OP stating that the HW pump is a bronze one. These are typically used in conjunction with extra 'return' pipework to circulate the DHW around the house so that hot water is instantly available at each tap without having to draw off some cooler water first. It's nothing to do with the primary circulating water. I would expect this bronze pump to be on a timer, so that instant hot water is available whenever the users are likely to want it.
Regarding relays on heating systems...
One of the original types of mid position valve used to have a separate relay, forget the make.
Also few years back I did a heating system which consisted of three different zones plus hot water etc and various pumps and that required the addition of several relays. It were A reet bugger. Spent a while working it all out, finished it off and on packing up found the schematic for the system in the back of the boiler manual !
So might pay to start by having a look at any info the householder might have, boiler manuals etc.
Reply to Why would a relay be fitted to a heating system in the UK Electrical Forum area at ElectriciansForums.net
I
Baxi system boiler and Opentherm Hello Does anyone know if its possible to connect an Opentherm thermostat such as a Nest to a Baxi 800 System...
Ian777
I
Anyone plumb a DIY hot tub? I bought a used acrylic hot tub shell that I plan to sink into the ground in the backyard. The plan is to heat it with...
siricosm
