Why would there still be current present when the circuit is off?
G
Gavthesparky
A valued customer has replaced all his Halogen GU10's with LED replacement lamps. For some reason three lamps on one switched circuit remain on but very dim when the switch is off. This room is switched from 3 points and depending on which switch turns off the lamps this has an effect on the amount of light produced in the off position.
I hope this makes sense.
Things I have tried already.
Replaced the switches.
Checked to see if there is a borrowed neutral.
Tried other lamps. It is fine with halogens but I imagine the current is only slight so you cant see any difference.
Turned off other circuits to see if there proximity had any effect.
The problem with a resistor is heat dissipation when the circuit is in use. The more I think of this the less I like the idea.
This is a bit unconventional but it would work.
Good solution, but it would require a rewire of the circuit.
How do you wire a two-way circuit?
Better solution would be to ask the manufacturers to install a 330K/470K resistor in the LED lamps.
well when i think of it, open switch and led's still glowing , so they must hold on to energy. on this theory, what about a cathode on the neutral
and forgive if a load of bollo cks
tele my friend your calculation is out by a factor of 10!!!!!!!
so it is. bloody decimals.! 0.16watts. thought it looked high, but had to go out for a beer and when i got back, i'd forgot to recheck.
