J
jeffporter
The wife has discovered that one of her ring main sockets is intermittent in its supply to her TV and is worried that this fault should have triggered the MCB but did not do so. Is she right to worry? She thinks the socket probably has a loose wire in one of the terminals. Is this likely? The ring main is fifteen years old. When she plugs in her vacuum cleaner into the same socket she gets the same problem. The vacuum cleaner starts up, then dies. Any ideas about what could be causing this?
It's the MCB not being triggered that worries her most.
