WIFI booster that actually works | Page 2 | on ElectriciansForums
Guest viewing is limited
Discuss WIFI booster that actually works in the UK Electrical Forum area at ElectriciansForums.net
london
Hello guys
short and simple, wifi hub downstairs with weak signal reaching the 3rd floor.
I have not used a booster that utilizes the final socket circuit cabling before, are they any good or would anyone recommend something else?
I had no joy using powerline adapters when I tried to get a signal to the log cabin at the bottom of the garden (it's on a separate consumer unit so that's maybe why) but this repeater worked a treat:
https://www.amazon.co.uk/dp/B01DP12RH4/
I don't know how it would work through the walls of a house rather than through fresh air, but as it's from Amazon if it doesn't work for you, you can return it for a refund with no quibbling.
Hope that helps.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Reply to WIFI booster that actually works in the UK Electrical Forum area at ElectriciansForums.net
Obviously not a building/DIY forum so will keep it short but yes - we've taken all the floors up. Several joists in the bathroom need doing as...
