wifi problems | Page 2 | on ElectriciansForums
Discuss wifi problems in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Go with orange mate, never had a problem
Not sure how Orange solves Wi-Fi problems you are probably lucky that you do not have too many co located Wi-Fi metworks
The only solution is to ditch Talk Talk and move to another ISP!
A lot of the problems can be solved by not using the supplied router that is usually cheap and past it's use by date as technology has moved on to get the best from any ISP you need to be able to set up a router which is a step beyond the plug and play solution most people are comfortable with
Most Wi-Fi routers are limited by the antenna that is supplied or built into it, if the router has a detachable antenna then changing it to one with a higher gain may / will / should improve connectivity depending on radio propagation, the building structure and other wireless equipment causing co channel interference , for routers that have built in or non removable antenna(s) then the options available are to use an alternative router or to install a wireless repeater.
We do get occasional loss of TalkTalk network connection but it always seems to be when the heavens open and it really pishes down. An almost daily occurence in t'North East. Although we've done quite well as of late!
My wifi worked perfectly for ages untill one day it just started slowing down and dropping out, spoke to next door and they had just got a new router. Turned out they were on the same channel as me and so were 2 others.
Download this
http://www.metageek.net/products/inssider/
It will tell you what channels the local wifi networks are on, then change your channel to a different one.
Tim
Reply to wifi problems in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Hello. This is such a noob question, but I'm struggling with something that seems like it should be fairly straightforward. I have numerous 24v...
Managed to get it online by doing a factory reset
