Wilex split load dual RCD CU | on ElectriciansForums
Discuss Wilex split load dual RCD CU in the Australia area at ElectriciansForums.net
S
SimpleSimon
Can anyone tell me if I could pick up the casing ALONE for a dual RCD split board. I've got all the parts just the casing n cover
[ElectriciansForums.net] Wilex split load dual RCD CU
There's one....
I was going to suggest you look for a CU of the appropriate size but containing only a main switch, but I realised this would not have the appropriate neutral bars. You probably can get an empty casing from Wylex, but it could be a special order from a wholesaler. Does it need to be Wylex though? Wholesalers may stock empty casings, even if only in their own brand.
Be honest the cost of them board with all the components mounted is hardly worth the time installing the bits what you looking at for a 14 way £15.00
having said that i need a front c/w cover for a wylex13 way board got a cracked one on a job
Reply to Wilex split load dual RCD CU in the Australia area at ElectriciansForums.net
He said something about a fused something as the lights hardly take anything .. I told him was mostly cordless tools so just chargers ..told him...
Yes I touched on diverted neutrals when I went over guidance note 3 the first time but I’m doing a second round and going between all books whilst...
