Will replacement panels of same total capacity jeopardise FiT payments | on ElectriciansForums
Discuss Will replacement panels of same total capacity jeopardise FiT payments in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Mid Wales
Hi all, as per the above title. If one is to replace the existing solar pv panels for a new system of equal capacity (existing system is 8 x 250w=2000w total) with 5 x 400w=2000w in total, will that risk jeopardising FiT payments. By doing that it would give enough room to add 4 more panels of 400w but not connected via FiT meter. Obviously 2 separate inverters would be in use (the existing 2kW inverter currently in use) and new smaller inverter installed to its side.
So, the total generation capacity to the household would be 3600w. In your opinion is it worth it doing this?
And also would there be a possibility of connecting a storage battery (on order for the original 2kw system but then i had this idea of expanding the system and splitting it). The battery will be AC coupled through the original inverter, but could it be also connected onto the smaller one to have a feed from the additional panels (could it have a dual feed?)
I don’t know.
When I fill in my FIT meter readings, there is a check box for “any changes to system” so it must be there for a reason.
The only thing I can think of is it’s to get out of paying you… by changing something you’ve maybe broken the contract that was made when they agreed to pay you.
I just wish the FIT payment went up with what they sell electricity to us now.
Reply to Will replacement panels of same total capacity jeopardise FiT payments in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
Hi My first post here, so apologies for any mistakes. I think it will be DIY job with electrician sign off if required, but would like to do as...
