HappyHippyDad
Supporter
Morning....
I have a chap who wants 30mA protection on all his circuits.
He currently has the main switch as seen in the picture below showing the whole CU
Will the RCD below fit into this board in the same place?
The one he has is marked WSEM, the one I can buy is WSES. Are these interchangeable?
If they are not then I may try and convince him just to have 30mA protection on the circuit I will be working on. So my next question is, is there an RCBO which will fit this board?
Cheers.
It's not...but if HHD wants to replace it with a 30ma unit to suit his purposes all he has to do is state on the cert it was replaced because it was duff. Who's going to know any different.
HHD will.
We've all told little white lies, or down things we shouldn't have; thats up to the individual. :)
In this case, after installing the new 30mA RCD, he could ended going back there more times than he might like.
We all know its not the correct thing to do, hence why HHD has posted here to convince him otherwise.
HHD, if it was me, I would Just replace it with 30ma and put on EIC it was like for like. If it does nuisance trip, and I would pray that it does sometimes lol then it will be a nuisance for the home owner........who deserves it as he has been a nuisance to you by telling you your job :)
He really is a bit of a nuisance TJ, one of those that simple will not listen to reason, whereas most customers listen to your advice and take it. Your post made me laugh:)
I think from the back of my mind the difference is one is designated as the main switch hence WSEM(ain) and the other was for the split load board hence WSES(plit). Are they interchangeable theoretically no, will it fit probably.
Thanks for that Westward, thats useful info.
According to my old Wylex Cat. 1995 and taking the point Westward10 made regarding M it is an 80mm RCD and was available in 40, 80 & 100A with 100mA trip only The S one was only available up to 80A in 30mA I think your best bet is to ask Wylex if it will fit but the way the catalogue is set out it seems not as you would not have the M or S.
As above Anthony, thanks.
Sounds like my memory is correct Ant.
I've contacted Wylex tech, they have 2 people working there, one is on holiday and one is sick! I've sent an email so when I get the answer I'll let you know...... but only if you're wrong as otherwise you'll just show off. ;)
HappyHippyDad
Supporter
Gloucestershire
United Kingdom
Will this RCD fit into this board?
HappyHippyDad,
westward10,
