will this wiring set up work?
sorry still got spacing problemtypes fine then bunches the wordsand when i edit i get a blank page to edit
@clydey, thank you for going to all this hassle,
my car defenatly has the MEMS 1.9, the colour wire going in to pin 86 is the grey/blue as you mention. not looked on the ECU as its at the back of the car and hard to get to it to take off the connector to see, but the relays are at the front of the car and easy to look at and take out
I am sure mine, even though its a MEMS 1.9 would be like the description you mention, would placing and LED (light emitting diode) on the ECU side of the connection I'll be making (location "C") stop any problems occurring?
Been busy this weekend doing a dummy run with the RFID before I fit it to the car, to be sure it works,
here's a couple of clips showing a dry run before I fit it to the car
RFID1 - YouTube
RFID2 - YouTube
One thing I was wondering, I have a Bosch S5 battery it's a 52 Am, do these RFID's use little AH to run? I've looked on the net to find out how to measure the AH of the RFID with my digital multimeter but with little luck
many thanks
