G
Glen Powell
This company at present supply their own inverters as a number were installed with solar inverters which did not perform, the capacity is 1.5kw so pretty small however flies below the radar under micro wind, it is possible to install multiple turbines if you have the space.
Tesco's did not take theirs down and there has been no complaints, I am not going to jump up and say they are the best think since sliced bread, we have recently put 3 up on our own test site to monitor, today we have also decided to add GSM metering to then publish live data to our website. We will also be adding another PV monitoring device to the system that will be able to work with wind very soon.
The web interface is supurb but will not be released till June so in the mean time we will use GSM data, start speed 3.4ms optimum 12ms
[TD="width: 168"]Turbine Type[/TD]
[TD="width: 9"][/TD]
[TD="width: 389"]Upwind Horizontal Axis with Acoustic Diffuser Ring[/TD]
Rotor Radius | 1.0m / 1.04m Diffuser | ||
Swept Area |
Nacelle Weight | 37kg (52kg including rotor assembly) | ||
Start-Up Speed | 3.4m/s | ||
Rated wind Speed | 12m/s | ||
Rated Power Output | 1.5kW | ||
RPM at rated Wind speed | 450 RPM | ||
Generator | Permanent Magnet | ||
Governing type | Angle furling/Dynamic brake | ||
Governing wind speed | 14m/s | ||
Shut-down Mechanism | Dynamic Brake | ||
Control Included | Yes | ||
Grid tie version | Standard Product (include inverter) | ||
Electrical network viability | 50Hz/60Hz 220V/230V US, UK & Europe | ||
Battery charging version | Available on demand | ||
Hot Water System | Available on demand | ||
Phase configuration | Single | ||
Mounting system available | 4 mounting systems available | ||
Acoustic Emissions | <35dB [A] [CE Certified BS EN 61400] | ||
Product Life | 20 year design life | ||
Turbine Class | BS EN 61400 Class 2 | ||
Warranty | 2 year manufacters warranty (return to base |
