Wire lighting
smartspark
Just installed a gyroscopic wire strip light with five L/V fittings.
Is there anyway to get these darn things completely level, I`m worried about pulling the fixings out of the wall. :eek:
Any ideas folks?
Ok I think my wording could have been better, I`m level, I`m trying to get the cable nice and tight and straight, it has a bit of a bow in at the mo with the weight of the fittings and the fairly long span, can this be achieved???
I know some systems have intermediate supports. Did a 230V wire system that had to span over 10m! That had 3 or 4 supports which were made of thin high tensile steel wire. Nightmare job that was but looked good when finished. We had to get some steel plates made up to bolt the tensioners to and then resin anchored the plates to the wall and plastered them over. The wires were so tight you could play a lovely bass note off it! :D
Any ideas folks?
Your never going to get these lights or wire completely level. Had the same problems on a recent project in several locations. If you get them level one day, they won't be then next, the wires stretch and there's nothing you can do about it i'm afraid mate!!!
