Wire Strippers | on ElectriciansForums
Discuss Wire Strippers in the Electrical Tools and Products area at ElectriciansForums.net
Dan
Staff member
Admin
Mod
Solutions
Staffordshire
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
I find these the best
[ElectriciansForums.net] Wire Strippers
So no strippers? Think I have knipex pliers - or at ,least red and yellow.
With wire strippers, most of us find that it's not a case of which type is best, because different cables require different methods of stripping.
Yes, you could use side cutters (or{insert favourite stripper}) to strip most cables, but there is merit in having a few types to hand. For example the Knipex Ergostrip is brilliant for round flexible cables, but unusable on twin and earth.
PS while you're here @Dan I don't know if you know this but I get this message at the end of every thread -
"This thread hasn't been replied to for 14 days, so replying to this one may not get a response. Post a new thread instead."
which wire strippers are the best out of these?
I have used the CK "automatic wire stripper" and it is great for PVC T&E cable. Not very good for XPLE insulation, and not so great for round cables, also I used an angle grinder to remove the palm-biting parts of the inner handles.
I have a similar cutter, but that has two stripping holes and not the other features, but found it annoying trying to cut wire and it getting only partially cut unless I carefully positioned it at the outer half of the blades.
I end up in attics a lot, so try to take the minimum amount of tools with me.
You're right with the cutting width being a bit short, perfect for 1.0 mm / 1.5 mm t&e.
The cutter for the screws is brilliant.
Attics/as few tools as possible...very good point! I carry the CK side cutters/strippers with the bolt cutter bit, and Knipex installation pliers, which are fine for pretty much most jobs. The CK automatics are great for t&e and the CK shears are excellent too, especially for heavier cables, but if just a small job doing lighting etc. in an attic, the first two are fine.
Screw cutter is indeed brilliant and CK conveniently provide both M3.5 & M4 in my side cutters. Problem is those side cutters are usually still in the toolbox when I need them.
Reply to Wire Strippers in the Electrical Tools and Products area at ElectriciansForums.net
I'd go for strippers every day, wire and cable are just plain boring! Definitely get yourself a stripper! (Failing that Id use ck crops)
I'd have thought this is way more risky in catching the inner insulation and definitely slower
