Wireless Light Control | on ElectriciansForums
Discuss Wireless Light Control in the Lighting Forum area at ElectriciansForums.net
dprance
London
Hi.
I've just had my a big renovation done and I stupidly forgot to tell the electrician to include a lighting circuit for the kitchen cabinet lights. These can go directly into a plug socket but I would prefer for it to be controlled by the main wall switch, without having to use an app or anything. Something simple.
Is there such a product that can be added to a lighting circuit (i.e added to a spot light and then hidden into the ceiling) that would automatically transmit a signal to plug-in socket adapter to tell it to turn on once the light has been switched on? Would be a pretty neat thing and would save the hassle of having to run more cables/redecorate.
Advice appreciated cheers!
Something like this ?
Yes I've seen these - something really similar expect I want to be able to use my existing wall switch.
Essentially I want to create a wireless spur off an existing light circuit so that when you flick the switch the light comes on as normal but also a signal is also sent to a socket to turn on/off.
Reply to Wireless Light Control in the Lighting Forum area at ElectriciansForums.net
Neutral and live
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
