Wireless Programmable Thermostat wiring help
no it's not...The CPC isn't connected, there is no strain relief and the termination itself leaves a lot to be desired.
apart from that...
black to com and grey to N/O normally open on the receiver.
That is the law simple as
And not third party either as gas safe are the regulating body
That is not the law, that is a leaflet produced by gassafe, the law can be found on legislation.gov.uk and is titled Gas safety (installation and use) regulations 1998
Gas safe is the body currently licensed to maintain the register on behalf of the health and safety executive,
Yes what does it say, will be some iteration of you must be qualified/ hold the reverent qualifications
Also why do you think boilers come pre wired
Have a read
Domestic gas health and safety - http://www.hse.gov.uk/gas/domestic/index.htm
They come pre-wired (with a link in the thermostat connections) because they are tested before being dispatched..
Are saying that electricains can't wire boilers up because they are not Gas Safe ?
Of course, I understand you shouldn't be taking the cover off of an Gas appliance but we are not dismantling the boiler, to get to the burner etc we have to remove another cover which I would agree, Non Gas safe people should not be removing.
correct and there not tested eg fired up/ connected to elec
still doesnt matter your removing the cover, which under law you cant do unless your gas safe or its decorative (no screws in cover)
Pretty sure the newish Valiant Boilers have no screws in the cover, just clips at the bottom.
I was on a job and gasman was with gas safe inspector was there, the inspector was fine with me removing the cover to do electrical connections and didn't call the police.
Gas man was still on site and probably hasn't commissioned the boiler yet
rustynails,
Corbs,
