Wireless Smoke & Heat Detectors | Page 5 | on ElectriciansForums
Discuss Wireless Smoke & Heat Detectors in the UK Electrical Forum area at ElectriciansForums.net
With new legislation in Scotland coming in shortly i was wondering what's peoples preferred maker of 10 year lithium battery smoke and heat detectors.
I have big problems with the Aico radio link alarms, every time I go to my garden office for a crafty smoke I set off the alarm in my office which sets off the alarm in the house, the smoking is not so secret anymore.
#40 did mention this, and you replied #48...but if you now have stock in maybe you will win having beaten the price rises!
I did the Aico installer webinar thingy, and got a certificate, but i can't see a van sticker anywhere.
I sent Aico an email to remind them about the van sticker. They sent a pack of 5.
Keep a latex glove in that office.
Folks in Scotland should be proactive in pushing smoke alarms, for any gaps in their schedules. Not every householder is going to leave this until the last minute and if you don't take the work somone else will. Might be worth mentioning the issue to customers and dropping a hint that, as time passes, a lot of work could end up being squeezed in at weekend rates.
I’ve got a note going out with current invoices mentioning the new Scottish rules, and I think I’ve got 4 jobs to fit in so far (my own house being one)
was at CEF this morning and the lad said they’d had loads of orders for detectors, so sounds like the other sparks round me are doing the same.... or they’ve got housing association contracts.
I didn't get a van sticker, just a PDF Certificate...
I don't have a van, but still...a sticker would be nice!
Haven't had a sticker since i went to the dentist when i was 5
Just a little update on this one guys,
The Scottish Government HAS delayed the date by one year, updated info published 30th December.
"Given the impact of COVID-19, and the difficulties this has created for people seeking to install new smoke and carbon monoxide alarms, we asked and the Parliament agreed to delay the implementation of the new standard until February 2022."
Source info
I've fitted some of the Aico battery ones (EI650RF) recently as a bit of a trial at a premises belonging to my in-laws on a temporary basis until they renovate. Seem like decent alarms, very straightforward to fit and link. Having previously fitted hundreds (if not thousands) of Aico products in the past I'm hopeful that there should be no issues with thee new ones. Only time will prove the life of the batteries. I also incorporated two of their battery-powered manual call points (EI407) at the same time which I was impressed with. (Word to the wise - put the manual call points into link mode before any of the detectors!)
For 5 smoke detectors & 2 manual call points it came to about ÂŁ430 delivered (ordered from CEF website) but I had them fitted and linked in less than 30 minutes.
Our local council & housing association have both approved the sealed-battery alarms to be fitted when upgrading to LD2 if there is no reasonable way of obtaining mains power to the desired location.
Or just use wireless interconnect battery only units
In the Aico series that doubles the price of the units, this of course can be offset by the cost of installing cable to each unit, its a conundrum, install the better units (3000 series combined CO/Heat/Smoke) and run a mains cable to them, or take the convenient route and instal more units at a higher cost per unit.
In the Aico series that doubles the price of the units, this of course can be offset by the cost of installing cable to each unit, its a conundrum, install the better units (3000 series combined CO/Heat/Smoke) and run a mains cable to them, or take the convenient route and install more units at a higher cost per unit.
I guess that is very property-dependant, etc.
If the house is being rewired it would be crazy not to put in a wired alarm, but I suspect for the majority of cases the more expensive battery units are going to work out far cheaper than running cables in (assuming the situation permits battery-only systems).
Yes, the expensive battery units should be cheaper to the customer, but after 10 years they all have to be replaced at the same price again.
With wired, you only have to replace the detectors, the extra cost in wiring is negated for future replacements.
It’s down to individual customers how much disruption they want.
On a side note, detectors with PP3 battery’s are no longer suitable to meet the new Scottish standards.
However, if not used in the specified locations of landings, kitchen or living room, I would think they could still be used as an addition to the standard.
Reply to Wireless Smoke & Heat Detectors in the UK Electrical Forum area at ElectriciansForums.net
This is it though…. To put one following the letter of the law, so to speak… would be a smoke in the hallway outside the bedroom door… then a heat...
Personally I won't do fixed price work unless there is a clear spec for the job including things like smokes, data, TV whatever else the customer...
