Wireless UFH thermostat | on ElectriciansForums
Discuss Wireless UFH thermostat in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Pretty Mouth
Warwickshire
All of the UFH thermostats that I have ever fitted have had the air temperature sensor integrated into the hard-wired wall mounted programmer, with the floor temp sensor cable also connected directly to it.
I have a small UFH job where the UFH will be the primary heat source, so an air sensor is necessary, but the room layout makes it difficult to have the air sensor and programmer located in the same place as the floor sensor.
It would be convenient if the programmer and air sensor were together in a battery powered unit that could be placed anywhere in the room, while a hard wired 'receiver' with connected floor sensor were fitted elsewhere, the 2 units communicating wirelessly.
Does such a product exist? Or is there another way to achieve the above?
Nest is your friend for this. Have done this many times - receivers based at the UHF manifold and the sensor remotely in the zone.
Thanks @Rockingit . Just to clarify, I'm talking about electric UFH, and it sounds like you're referring to a wet system? Can Nest be used with an electric UFH system?
Certainly can. When you set up the system it asks you for the type of energy source - and at the end of the day it‘s just a switch the same as any other sensor.
Reply to Wireless UFH thermostat in the Electric Underfloor Heating Wiring area at ElectriciansForums.net
Unfortunately I don't think you will get an "off the shelf" diagram for the system you are trying to do The Wiser system is very adaptable but it...
As a "temporary" measure I went down a slightly different route. Nothing off the shelf appealed. In particular I wanted something with a good WAF...
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
