L
leenowell
Hi,
I need to complete the wiring on a 2 boiler system with several heating zones, UFH, secondary return loop etc. Each circuit has a 2 port motorised valve controlled by timers/ prog room stats and the relay side of these valves all return back to fire the boiler once opened. I have wired it all up to one of the boilers and it is all working fine. My question is.... Can I simply wire the second boiler in parallel with the first? I was thinking that the valves prevent any backfeeding anyway and the end result is that I need both boilers to fire if anything calls for heat?
thanks in advance
Lee.
thanks in advance
Lee.
