H
hollieH
Hi,
please could I have some advice. I have the musik wall lamp from ikea and have wired it to a plug. The wall lamp is 250V max 40W for bulbs. It has 5 bulbs and I've chosen each to be 3W. I bought an ikea plug which has just the live and neutral wires and no earth wire. It is three pronged however (one is plastic). The plug has a 3A fuse and allows 250V.
So far I have stripped the plug wires and connected the live and neutral into the 'choc box' inside the light. This is where the instructions say to put the wires in which come from the wall. I've screwed down and made sure no copper is showing. finally, the light is double insulated which is why I think it has no earth wire.
I just want to find someone's opinion on the safety of this. I've seen loads of people do this online who have had advice from electricians saying it should be safe however I've also seen electricians say not to do it on other forums. As all the voltage matches and I'm not overloading with the wattage of lightbulbs I don't see what could go wrong, unless I leave a wire exposed etc which I haven't.
I'd love to hear your thoughts ! Thank you !
